24/7 Cranks
white-lightning
Well basicly i am after some cranks to get me riding again, and have seen some of the 24/7 cranks. To me they look fairly good but never actualy seen any in action. As far as i know they come with the 24/7 frame sets.
What are they like?
Stronge or weak?
What sort of price would i be looking at?
(This is not a wanted topic)
Thanks again Ash (Y)
Edited by white-lightning
Hello Ashley.
I have some cranks a bb and a screw on sprocket and a brake you can borrow until you get your's. I know one of the cranks has slighty rounded, but if you carry a 8mm all will be fine :)
You have got your wheel now rite?
And I'm sure Peter has a cable disk at his that he won't mind lending you, If you have a lever and a cable :)
You need to start riding agian boy :)
Your good friend,
Callum.
:D
Now then mate, thanks for the offer of lending them bits, im going to give it a miss this time mate. Im going to get it sorted soon. The wheel will be done very soon, also the cranks i think i might have sorted some 24 seven out till christmas :D.
cheers
I think people have got the wronge 24/7 cranks im on about. These are the ones i mean. :D
Yep, there NOT the ones i was thinking of, same company?
Forget what i said above, its probably of no relevance to the ones you are looking at, sorry.
Go on tarty and have a look at the crank section. None are welded for a reason..
The 24/7 cranks i have are definatly welded, and have definatly stood up to at least 3 years of stick on various downhill tracks up and down the country from a mate of mine (admitedley on a full susser) and if i remember right, another 3 years at the hands of me on my hardtail, both arms are in one piece, no signs of failure around any of the welds, and the threads, axel and bearings are still fine (think my mate changed the bearings from the origional ones, but i have not so much as touched them).
I agree, none of the cranks on tarty are welded, but if there is a reason why, what is it? I am assuming it is mostly due to weight, or is it that a steel weld is superior to an ali weld, and ali is used to keep the weight down, hence no welds?
Sorry for warbling a bit.
Mike
Edited by mike137
Mike
Ow thanks for the info. well i persum that if the same branded cranks are lasting on a downhill bike then i think the trials cranks should be ok for a few months.
cheers Ash (Y)
Agree 100%, but surely the forces involved with downhill are far greater than those on a trials bike; due to the terrain, speed, weight of the bike etc etc?
ok you go do a 20ft drop to rear on a trials bike with those cranks :D, trust me forces are much greater because of the 0 suspension.
Did i mention i ride a hardtail?
I agree that the forces will be transferred better because of the lack of suspension, but there is still no way that the forces are greater, i have the broken parts to prove it, including a set of forged cranks, marzocchi fork uppers (two big cracks on the crown), pedal axels, seats (dont ask) and hubs.
