Magellan Tucana '08
Mee(ukkraine)
Frame - tucana '08 short
Fork - koxx forxx with welded crack :(
Bar - truvativ team 35mm rise, 680mm
Stem - trialtech
Brakes - HS33 with 4-finger lever blades, front with homemade pads, rear with koxx browns
Front wheel - onza custom drilled, quando drilled hub, dt revolution, kenda blue groove folding stick-e tyre
Rear wheel - RedForce rim single walled and custom drilled, chris SS, dt revolution, try all tyre
Cranks - try all 175mm
Pedals - mg-1
Bb - truvativ gigapipe sl 118mm
Bike weights 9.3kg
Hope you like!
Michail
Edited by Mee(ukkraine)
