Trouble With Hydraulic Disc Brakes !
Trials D
Right I'm changing the pads on a hydraulic disc brake ....
But I'm not too sure how to do it .. :unsure:
...Because the brake retaining pin has to be undone by a Allen key.... right?
Well my Allen key whole (thingy where you put the Allen key) has worn away :S:o
So how do i get my pads out ?..... Or is it just me being a trials dumb dumb ? :ermm:
Edited by Trials D
I,d say try bigger allen key next size up or get a flat headed screw driver .
Small question on brakes am running hs33 for rear and i use tar.
I got the biggest block of tar from a guy today at work, new stuff aswell but it rock hard and it won't go soft on radiator.
any ideas any one?
So if I take a block and break it into equal small pieces and say place in the oven for a short while would that work?
AND would it stay managable after it cools down?
Don't put in the oven, just get a match or lighter... hold it on for 5-10 seconds then quickly onto rim.
You've got about 5-10 seconds until it goes back to being hard. :)
Oright I see I just thought it would stay soft, Oh well cheers Stu (Y)
The question about the tar, I'd say the best way i've found to use it is to get the wheel spinning really fast, then literally just push the block of tar against the rim, the friction of the wheel should easily melt the tar on the rim. About undoing the allen bolt, if there's any bolt sticking out just get a pair of vice-grips or some kind of locking pliers to hold onto it. Then the pads may well be held with a little bit of magnetism but just pull them out and re-do the process backwards....
OMDZ A Tar Question in NMC?
LOL Mitchell break off small bits, never leave the house without it, Even when your not on the bike.
YHYH
i put it in here so i didn't look a d!ck putting it in full members nothing was happening with this thread any ways .lol
