No Squeel
orange*zero
my magura hs33 do not squeel when the pads hit the rim is this the pads ? when my mate had his on the same rim it used to squeel all the time and i like my ears to know that my brake is working LOL if its the pads what do you recomend for a nice noise and good hold im using a mavic d521 rim :rolleyes: thanks ben
Most important question is: Does your brake work? If it holds and is quiet then to be honest you've got it made. I much prefer a quiet brake because it makes everything seem so much smoother (a few years running double disc is testament to that). It takes a bit of getting used to but when you do it's so nice not to be embarrassed to pull your brake in public!
i think there green frog not sure though as i got them in the brake when i bought it and smoth rim no tar. thanks ben
Green Frog? Never heard of them. The reason why you are gettin no sound outa your brakes is cause it's a smoooth rim. If you want the squeel get some decent trials pads and either grind your rim or use tar on your rim. Try Tartybikes or the Heatsink website, Heatsink make some awsome pads.
Sure the frog pads are for ceramic rims?
"Green Frog - Performance pads for all hard anodized(black) and ceramic rims offering greater stopping power particularly in wet conditions."
Anywho, try some tryall croco pads if you want some grunt. (with a grind)
But! if you like your rim, then could go for a softer compound with tar?
hope this helped.
Edited by Dave!
I never get brake squeel on my HS33. I have used all sorts of grinds, as well as a smooth rim and rock blues as well as phat pads. I get more squeel from my front disc.
Do you run a booster by any chance?
