Magura Water Bleed
jambo
Does anyone have problems with water bleed magies in the heat, seems one of my pistons is not returning, i know there can be problems with lack of lubricant?
Edited by jambo
thanks boys i lubed the s..t out the thing re bleed it with water again and it runs miles better than i ever remember.
Thanks for the speedy replies though. X X X
You will need to relube the slaves every so often when the oil dries out/washes off. I used to do this to fix the sticky pistons but it made a mess of the pads eventually (too lazy to clean it all off properly :$ ) but the emulsion I came up with lubes the same as oil does but still keeps the lightweight watr feel :)
