Can I Use Disc Hubs If I Want To Ride With V-brakes?
Herr.Wolfkatze
Yes its fine, I asked the same question and was told that people in your situation dont buy disc hubs if they can help it because of the weight issue.
True, but if weight isn't an issue and you might want to consider a disc later on in life then they're good to have.
(Y)
(Y)
Exactly, hence why i'm still reppin' dual ISO's for the masterplan™...
Having come from using two non-disc hubs in the past, they're pretty pointless, especially on the front - loads of hassle if you want to change things. Having disc hubs leaves you with your options open, you can run whatever set up you like (Y)
