Shimano Cranks Adapted To Ffw Sistem
MATRIAL
Hi, im Matías Pioli from Argentina and, thats the new set up of my bike
that the old pic
heavy cranks heavy rear wheel ( becouse of the screwed freewhell you fell the bike balanced to the rear end) , 1.300 gr fork ! (undestrunctible but.. ,,viz 120*20 stem
and now
Front rim ( whitout qr ,,)
Rear rim
DEORE CRANKS FFW
the insert and the threads , (aluminium insert)
The weight
echo+echo bash+ worldcat ( red one less holes)
deore + sl bash + worldcat blue
Fw so close to the bb shield ( need a new 124 mm octalink bb, came in friday)
fisnish build
New specs
Zoo Pitbull 07 long whit some holes ( front , bb , behind the booster)
09 urban fork v brake + disc
echo headset
pro fs bars ( from 670mm to 730 mm whit some wood)
echo sl stem 130 *18
drilled brake levers ( deore and avid)
shimano cables
old lx style brke arms
echo grips
kenda karma 2.1 front tire , 450 gr +-
maxxis high roller 2.5 dp rear tire
cst inners
light hib radial laced to weinnman 30 mm rim ( single walled and square holes)
echo sl laced to echo 42 mm rim ( single walled
kmc kool chain
deore cranks ( mod to fit ffw)
worldcat freewheel
echo sl bash
mag pedals
home made tensioner (with v brake arm)
weight 9.7 kilos , like 21.3 lb
New parts comming ,, echo 09 control long, titanium axles for the pedals, continental or bontrager rear tire, some pimp niplles , maibe in green.
and thats my new cat hahaha
comments are wellcome ,, thanks to Chris Bruce for the new parts.
sorry for the bad english !!!
I don't think I could ever trust a freewheel with holes drilled in the drive shell! I broke enough of them as it is without making them weaker.
Nice work with the cranks though, good effort!
i use this fork since september of 2008 ,, never skiped,, i dont think those holes are in critical parts ,, but also dont remove to much weight,,, i have a friend who broke one of the thotts and rewelded to the freewhell, hahaha i don´t trust in that kind of stuffs !! , yesterday i try the cranks ,, after thigten the ff the cranks feel so response and the bike super light ,,, next modification will be and echo control 09 , and some conti tires to keep the bike a little abobe 9 kilos ,, thanks for the comment
i dont think that you have a FORK with a drilled driveshell, it might be a freewheel i dont know, maybe im wrong :)
jaja vamos con es bike pioli felicitaciones.
haha tenes razon Frewhell ,, not fork ! dumbass !!
