Making Profiles Louder ?
Oliver gu
im planning on buying new hubshell cause i needed one anyways so will probably give it a good going over then ... just wondered what people thought and i guess running it dry is a big no no ....haha
Lube or grease usually helps a lot.
lol that makes it quieter and putting grease in it can stick your pawls down to your freehub body, wich is bad. Just do what callum sed, and bend yor springs slightly to give them more tension on the pawls
Edited by WIGAN
thanks ... didnt think about doing that tbf ... will bending the springs a little make it more responsive but lower the freewheeling capacity ...:P
Dont do anything with it, profiles are expensive and effort to service and unreliable at the best of times, stop being a nonse.
quite happy to be a nonce mate XD .... was just a question
My profile is loud, i had to strip mine down to replace the shell so while it as in bits gave everything a proper clean.
For lube i just smeared four stroke engine oil over the prawls an bearings with my finger.
thanks man :) .... my new hubshell is coming from profile soon ....ill have a gander when i change over the internals :)
thanks
