Rear Hub Play.
2FST4U
What hub is it? I'm guessing you ride mod, this gap/play is probably you are missing a spacer that came with the hub or you are missing a snail cam. Some mod hubs are 110mm sized but the frame is 116mm, snail cams are 3mm each. So 2 snail cams plus the hub makes up the 116mm spacing.
