My 20" Czar Mod Bike Check
esfrost
My bike check:
Frame: Czar
Headset: CB Iodine C
Cranks: Try-all 165mm
Pedals: Wellgo Mg-1 Ti
BB: Reset Ti
Rockring: Trialtech Ti
Bar: Monty 221ti
Stem: Acor 150*35
Grips: Neon
Brakes: Hope Mono Trial 160mm
F. Wheel: Try-all rim, Author hub, dt spokes, Maxxis CC
R. Wheel: Try-all rim, Echo Tr Hub, dt spokes, Alloy niples, Maxxis CC
Fork: Modified Echo Lite, 700 gr
8.7kg.
Mat Smith!!:
I got this here (Hungary) from a normal bike store called Mali. Its almost identical to the famous trialtech. Its also pretty light, and believe it or not, its very cheap, which means it was 4.500.- HUF wich is something like 15.- gbp...
That is very nicee!! However may I ask why have the chainstays been filled in?
The Headtube look really well done too :)
Oh and LiamWood! if you look closely it has a TI trialtech bashring inbetween the bb and frame.. Bit like what ali c and Tarty adam done with their bikes.
Edited by RossMcd
Yeah, it's where Ali did his! :)
The bashring sits on the bb cup. The forks legs has been drilled out at various places, like the legs and the bottom of the tubes, the upper middle where the forks joining into the body also has been drilled and filed out. After the filing and drilling i gave it a nice shiney black paint.
  • 1 month later...
