Rounded Leeeeeeeeeeeeson
BigAl
Rounded mounts on a leeson frame, what do you do to sort it?
Guessing its not the same as helicoiling... I cant say anything else now, as im tired and ran out of stuff to say about it. Help please?
Helicoil it same as normal :) Failing that. weld inside the hole then get it re-drilled and tapped.
anyone experienced the wonders of the leeson brake mount fix? i had it done on one of my old frames (black mamba). clive leeson bonds short threaded studs into the frame so that the mounts slide on and are secured by washers and nuts. pretty good fix to be honest which made brake setting up easy! doubt he does that anymore though...
