Gu Typhoon. 08 Or 07?
dirt jumper jake
I've got an 08 (20" + 26" :P ) . About the 20" though, it rides really nice and lively which ive found makes it feel lighter than it really is. With Lites on, the geo comes out at 1035wb 363/5cs and +55bb. I pretty sure the only problem regarding the snapping of the downtube just above the front bash mount is only when a bash plate is used as it concentrates the stress on that point. Running just a bashring seems to be the way forward as the 'locating point' where the rubber block would sit into kinda serves as a small block bash, much like my 06 CLS Python (if that makes sense?)
Not much info :ermm: but hope this reply helps you somewhat! (Y)
im currently riding a Gu typhoon 08 and its cracked round the bash plate had it welded though its even stronger now :)
Ben if you snapped it, and then re-wealded it; Its not going to be stronger, and you havnt heat treated it.
Id get a cls pythong bus?
