Thick Steerer Tube And Routing The Front Brake Cable Issue
philth
Just built a 24"er up.
I'm running a Echo fork with a 5mm thick wall on the steerer tube.
I ran into the issue for routing the front brake cable through the fork to allow bar-spins and tail-whips etc..
Here is my solution.
~ Barrel adjuster from a roady brake caliper (the threads match the star nut).
~ Upper and lower outer brake cable sections.
The brake feels great (no slop) and the stem stays tight.
^_^
Edited by philth
A neat way would be to drill a small hole through your bar where it's clamped. Though it may be a bit sharp of a curve for the cable.
....and then a hole through a 5mm thick steerer tube, and then have to thread up your bars and stem onto your cable before you can fit your brake lever... :unsure:
