Boredom Strikes
rab shropshire
Right I have been of work for too long and a new baby means night time riding is out lol
So i decided to modify some things to see if i could make parts better, Don't know if anyone has tried this before.
First of I wanted to make some standard maggy mounts work similar to TR clamps,
Really simple cut your plastic washers and glue them into your clamps.
they work well i tryed them out and they set your pads up pretty square.
Second i wanted to see if a 4 finger blade would work with an 04 maggy, i had a standard 2 finger blade spare so afer a bit of fileing it worked. A bit more filing will move the lever blade further out from the bars.
if anyone is interested i can stick a pic up of where i filed etc
post-23109-049192400 1283456073_thumb.jp
post-23109-042314700 1283456081_thumb.jp
post-23109-026602200 1283456094_thumb.jp
I like the 04 maggy lever :D im guessing your not riding much now that mason was born! lol, will he be a mini you? :lol:
The plastic washers gradually deform which is the only issue with your clamp setup - a lot of the time when people have brake setup issues it's down to their cylinder washers being worn to the shape they had their brakes in last, so when they try and move their cylinders they just move back into the old position. Might end up being an issue with yours, possibly...
Time will tell if it works or not, i have tr clamps on my control anyway, but im building a bit of a mess around bike so just experimenting with stuff at the minute
Whats the mess around bike?
Will you stil have the control the next time you come up?
And are you coming up for Danny's memorialride? :D
