Rear Brake
thesubway
Hi, sorry if this has been asked before, can't find anything that answers my question. Right, my rear brake will hold and stop me when moving forward and landing on an object. But the issue I am having is it that it will slip backwards every time. Is this a case of me not pulling the brake lever hard enough? Or is there anything I can do to stop it slipping back? The brake setup I am using is the following:
-Hs33 '05 with brake fluid
-4-bolt heatsink brake booster
-Phat pads with cnc backing
-light grind
Any help would be much appreciated. Is it worth me trying different pads? If so what pads would you recommend.
Adam
yeah, maggies tend to grip better forwards than backwards, That pad material is also great for bite, but bad for hold (I spent ages looking for and testing loads of compounds before I found that material, so I have a lot of time with it). I found the best pads for hold were the koxx blox browns and TNN LGM and Bealay pads. a booster will also help, but could reduce bite
Boosters reduce bite? May have to go back to 2 bolt then... Em, you may have a bit of oil on your rim matey, give the rim a wash and see if it works.
