06 Gu Stock Brake Set Up Problem?
Andeee
Hi there guys i recently got a 06 stock 2nd hand of someone on here.
Recently i have come across a fault of setting the brake up. As the crank arm catches on the hs33 slave cylinder.
The set up im using is:
06 gu stock long frame
04 magura hs33
127.5 square taper b.b
170mm middleburns
czar brake booster
tensile offset brake mounts
42mm rear try-all rim
So far i think it could be the b.b or the brake mounts? As ive swapped the mounts from in to out set.
I can get the brake reasonably set up but the pad catches every now and then.
Anyone ever come across this fault before?
Andrew
possibly be becasue they are offset brakeclamps, is there any need for them? or if it catches now and then you could try a 128mm bottom bracket to get you a few mm.
I got the offset clamps as they were what me local bike shop had n they were off me pure. I am gonna try some standard magura ones which im getting of a mate for £5. But the crank has never caught the cylinder before only when it comes to re-setting the brake.
As for pics i aint got any.
