Leaver Body Problem.
onza blade 09
  • 2 weeks later...
You need to give the brake a bleed. But when you do this make sure that you push the air and oil through from the cylinders this is essential.
thanks mate allready tried that the lever wont press in so i carnt bleed it soo i think its broke i have allready brought a new one
In the leaver, were the TPA pushes into, the seal or cap what holds in inside the leaver seems to have been pushed down into the leaver, so far that the TPA cannot reach it any more.
Does anyone know how to pull it out or reset it to the normal position?
Thanks.
Sounds very like your piston in the master cylinder(part on the handlebars) has jammed,or you have a leak of fluid somewhere and there is not enough fluid in system.
Is your system filled with proper fluid or water?
I had a problem with my sons and it turned out needed new piston as old one had swollen(probably as system had been filled with water by previous owner of bike).
Replacing piston is dead easy 10 min job then re-bleed(not with water as no lube in system which is not good for piston.
Tarty supply piston & spring set for magura hs33'S at £9 posted (bargain buy)
Hope this helps :rolleyes:
Calum
