Rockman Bub Hub Bearings?
Borat
Take the old bearings to your local engineering supply place and they should be able to match them for a couple of quid each :)
edit: failing that the size of the bearing should be on there, typically moulded onto the plastic shield or etched onto one of the races. If indeed they are 6000-2RS then they should be 10x26x8 and can be bought from here
Edited by forteh
