Brake Trouble :(
superjay
ok im having trouble with my brake (rear)
sometimes when im gapping and mess up the back brake locks ups like the little piston bit in the lever wont come back out.
if i give the bike a good shunt back its all frees up again and works fine.
any idea what it could be what to do?
its only started to happen since i fitter heatsink yellows on there like there stinking maybe? but i dont use tar or a grind and my old pads never did this :/
i would send them to tartybikes or to my local shop but i wont get it back before the 2 rides i want to go on.
any help would be great
Sounds like the seal in there is drying out.
For a temporary fix put some oil in there from the outside.
To fix it better take the lever off the brake and poke the piston out from the bleed hole and lube it up in there nicely.
This shouldn't happen if you're on an oil bleed though.
I always fixed it by replacing the lever lol.
well i will try and oil it up but im use royalblood in there anyway.
and mine lever is not old i just got it fixed of tartybikes a few weeks ago and the fitter a new one and the did something to the piston cause it was leaking.
Are you sure you havnt got the lever bolt done up too tight?
