Why Are Echo Sl Brakes A Pain In The A**
i like cunning stunts
Have you tried leaving the grub screw in but just have it slightly loose. Put bike on side and push the water/oil through from bottom, when you think its spot on tighten the grub screw but keep pressure on syringe.
Edited by gary-mac
They aren't any more difficult to bleed than any other brake. You need to set the brake at such an angle so that the air flows in the same direction as the brake fluid when you're filling it up (the same applies to every brake).
If you're bleeding it from the brake lever, the hose connecting the master cylinder to the slave should be at the highest point of the lever. Same applies to slaves, angle them so that they're pointing downwards at a 20deg angle.
edit: Found a pic of the way I set SL brakes for bleeding:
This is slightly incorrect, the slaves should be pointing down. But the brake lever is at the right angle.
Edited by Greetings
So bath bled it this morning and it went perfect, out all day today an hour in the ride leakage out the slaves so i had to rebleed using a kit and oil and it seems ok now just not as nice as a maggy with a water bleed so i am going to put the maggy slaves on this echo lever with a water bleed and see how i get on with it at shipley next week.
