Brake Booster Fitting
MPfive
Ideally, because the clamps are partly counter-bored for the screw heads, you'd be better running spacer tubes. You could go straight into the clamps but you might end up deforming the clamps as there isn't really a mating face to clamp onto. If you do go without spacers try and get some slightly longer screws to reduce the likelihood of stripping the brake mount.
