Singlespeed With Middleburns?
LROB87
newly got back into trials im clueless about this single speed era i've read on here somewhere you cant do it with middleburns but have seen a few people on here with exactly that whats the deal is that guy an idiot or do they have a deathwish? what teeth cassette should i be looking for otherwise?
you need one of these.
they go on your hub
people were probably talking about not been able to use freewheels on the cranks.
thanks bud! what about a chain tensioner?
isn't 18t better with 22 up front than 16? and will a tensile 60 click freewheel be ok on the rear?
Edited by LROB87
If you've got a fixed rear hub the tensile will work, if you've got a freehub then you need a set of spacers and a single sprocket. As for a chain tensioner you'll get away with a single wheeled one due to having to run a larger rear sprocket than 15t like this http://www.tartybikes.co.uk/sprung_tensioners/4jeri_tensioner/c48p10179.html
