My T-Pro
piperfraz
Okay, so I got my T-Pro about 3 months ago, with all the standard Onza parts.
Since then, I've upgraded a few parts and i decided to post a few pics on here.
post-29575-0-12390400-1308402901_thumb.j
Spec:
Frame: Onza T-Pro
Forks: Echo Team '07
Bars: Trialtech Risers
Stem: Echo TR 2-Bolt
Grips: Blue Echo Rubber
Front Brake: Onza Disc
Rear Brake: 2005 Magura HS33
Rear Brake Pads: Neon Greens
Rear Brake Clamps: Black Echo TR Clamps
Chain: Trialtech K810 Kool
Chain Tensioners: V!Z Snail Cams
What does everyone think?
Cheers,
Fraser
Edited by piperfraz
Go to an image hosting website such as www.imageshack.us . Upload your picture at the size you want. Then once thats done get the direct link to your image, copy it.
Come on here and in your topic when you writing theres a little image inbetween the envelope with a plus as the chain with a plus. A little picture of hills with the sunset, highlight over that and it should says 'Insert Image' Click that then paste the link you copied in there and click insert image. All done :)
Edited by mrBENN
Cheers
are that style of onza crank still square taper?
I had the old, alloy crank arm style cranks (the shortish ones from like 04) and the BB's are awful! i twisted it like anything but didnt realise till i took the cranks off for isis.
crank arms were pretty good though I give them that, pretty light I thought
Onza hubs were pretty awful on mine (I had 04 t-pro) got really gritty and developed a lot of play lol.
To be honest, not too sure :ermm: how do i check?
And yeah I have onza hubs on it
Bet that rides spot on !
