Running A Peg On Pro 2 Front
gee
I would like to run a peg on a front pro 2 and wondered if this was the best way about it.
remove QR adapter cone on both sides from , drill them to 10mm, and replace. buy m10 around 130mm in length ensuring only the last 10-15mm is threaded. push bolt through hub, cones should sit snug on bolt because only end is threaded. put back on bike with peg installed.
any better ways around it? i know i could buy hub with solid axle but would like to use pro 2.
