Riding Trials With Using Your Brakes
onzatrip
Hi there people,
Just a random thing was out riding on Sunday when my front brake starting playing up Realy bad, so I took it off. Before I took it off I couldn't Realy get the things I knew I could, eg taps etc, then when I took it off, I was riding a lot better. Being a lot smoother and riding bigger
Just wandering because when I tap, gap etc I always lock my front brake on, is it due to that or is it a mind set??
Does anyone else have this issue??
It's Realy confusing me
Thanks people!!!
Edited by onzatrip
bit of a mind set, if something is wrong on your bike, you'l be inclined to question it and worry about it, so you're preoccupied with thoughts of broken parts, and if your head isn't in it it won't happen. plus a bit of death grip never hurts...
Well its not ideal. Put your hand out like its gripping both bars, and then open your fingers out like you would when you brake you can see and feel the grip that you lose, so its harder to pull on the bars with less grip.
But will you start gapping further if you stop doing it? Probably not.
You hold your front break when you tap? That aint a good thing!
If your not locking up your front brake you can be busy doing more important things like using you hand to grip the bar and yank it harder lol
Not while I throw the bike up once I'm pushing the bike through!! And when I land you can see the wheel is locked!! Same when I gap the front is locked on..
