Onza Master
dezmtber
i now have an onza master.
which i got as standard spec.
since i have fitted an onza pro front wheel 28 spoke
hope trialzone brakes
rear VIS hub on onza pro diamond rim
nukeproof electron pedals
some pics of the new rear wheel and brake
i havent been lucky enough to try the old ones.
they feel much better than shimano deores.
more modulation on these. the deore is very sharp on the lever feel. but does not hold as well as the hope
i am running 160mm rotors front and rear.
in comparison to brakes i have ran before they are on par with the power i had from avid codes on 203 rotors.
i will give a full review when i have had them out on the rocks at the roaches and will quote on hold under the pressure of steep sections an how well it allows you to go and stop.
i have also set them up very well both wheels spin freely without any rubbing from the pads.
i had a onza master, was the best mod frame i ever owned till i snapped it, never found a frame that felt the same, always good to see another one those brake's look lush, but then so does your bike good work
Whats the geo? and any pics of your one?
Edited by Laurence--Trials
i just fitted a whole load of ti bolts. i got bolts for :
the bash plate x3 m6 counter sunk
the wheel axles x4 m6
the brake disc bolts x12 m5
the levers x4 m5
the top cap and front of the stem x5 m6
i am going to get the bolts to the disc mounts next.
rode the roaches today the brakes were awsome.
only problem i had was the rear started sqealing when i rode around. but still worked
fine maybe needs a bleed.
and this was before hope trialzones
i will get some fotage of the brakes landing gaps up and pics of the full bike, gonna go ride some pallets on tuesday
Edited by dezmtber
Why would bleeding it make it squeal less?
Hope disks do squeal. As long as its a high pitched squeal not a gobbling turkey style honk its normal.
  • 6 months later...
oops i should have put that sentence togherther better.
i meant the hope brake was squealing on its own without pulling the lever.
it needed the resovor topping up as a little air kept creeping into the hose.
later i found out the disc wasnt to fault with the squealing it was a badly agligned disc mount on the onza, sorted that i bought the rockman austin and now its all fine.
check out my rockman build
http://www.trials-forum.co.uk/topic/170224-new-rockman-austin-dual-disc-2012/page__st__20__hl__+rockman%20+austin#entry2360980
