Help
Jeromboii
Hi all. Need a bit of help. I have loads of play in my headtube. I am running Onza forks with a rockman manus frame. The head set is a brand new (3 days old) Echo SL. I have loads of play in the forks and I have all the washers in the correct place in the headset ? Can anyone help me to stop the play ?
Cheers Jerom
Cheers Jerom
has your new headset the same stack height as the old one?the stem/last stacker on to has to be 3mm higher than the steerer tube to allow the srcew to tighten the headset up-hope you get what i mean
