Spoke Lengths
pashley-phil
Can't find any listings of NoWar Hole rims, but with the Sky rims which I'd wager are very similar you want 268's. That's 3x on both sides.
A 2x makes it 260, 1x = 255, and radial = 253.
I know that's not any real help since the rim might be different - but still :P
Edit: Hub is 44mm flanges, and 44mm flange-to-centres. To save you the tremendous effort of looking, that was using an ERD of 594 and offset of 11 (reducing the flange-to-centres to 33 each side) here: http://www.dtswiss.com/SpokesCalc/Calculator.aspx
Edited by aener
