Should My Front And Rear Disc Brakes Be Making Such A Loud Screech
Luxeey
They can make noise when wet but otherwise usually contaminated. You'll need to degrease the disk and clean the pads by either sanding them as above or cooking them which burns off the contaminate. Then rebed them and they should be better than ever.
Sorry to hijack this thread but how do you cook them? simply shove them in the oven? and is it safe to do this with any disk pads?
Edited by Danny00135
My mate left them on the top of an electric cooker. It burns off the contaminate. You'll want to have a good extractor fan though as it produces quite a lot of fumes. You could probably do the same thing on a gas cooker if you put a piece of metal underneath the pad. Not sure about organic pads but I'd assume it would be fairly safe.
cooking really doesnt work on heavily contaminated pads its only good if you have a little on surface.
and be carefull as you can burn the glue holding the pad to the metal and cause the brake pad to delaminate and lose the pad material.
just plain simple wet n dry on a flat table and rub the pad on it. till the surface is dusty all over. then leave the pad for a min if the dry dusty surface shows blotchy wetter areas then the pads are knackered
