Sloped stem on forks cut flat?
will ackerley
If you imagine a line through the stem level with the bolts, that's the area of clamp load, if the forks are in the zone (with a few mm over!) then they might be ok, if there's a hole in the stem that the forks don't cover completly however, then the top bolts clamp load will be acting to push the top of the forks into it, which will eventually cause ware and problems.
In a perfect world, I'd slope the forks... because I agree with adam :)
  • Like 1
This. And imagine the loads when you land a dropgap for example. You want as much support for the stem as possible.
