Sprocket for best chain line on an Echo 24''
niconj
I'm planning on swapping my frame for an Echo 24'' Disc and was wondering what sprocket I should use for the best chain line. I currently run a Trialtech 14T on an Echo TR hub. For the current frame it's perfect but I don't know how that will be for the Echo frame. The Trialtech sprocket is on one line with the outer side of the threads and an Echo one is more to the middle.
Thanks,
Nico.
Should be alright, won't really know till you try it unless someone else has had the same setup
Which shouldn't be too hard as there are a lot of 24'' Echos out there and many will have the TR hubs as well.
