Chris King Disk alignment
BIG Drew
Not on a trials bike it is on an Orange Five but there must be more of these on trials bikes than anywhere else :)
Just brought the hubs second hand.
ISO hub, HD axle + Fun bolts
It looks like the end of the axle (Where it meets the frame) is too far away from from the disk mount on the hub shell. (By about 1mm)
This means I can't line my calliper up with out bodging either the rotor further left or calliper further right with.
Is there any adjustment for this in the hubs. To move the whole hub shell over on the axle. It preloads the bearings fine and there is no play..
Also what are people using for lube in these.. I've got some 10wt Synth engine oil in and it is silent.. A bit more of a hum would be nice!..
This is the rear hub I am talking about by the way. Front lines up fine
Frame is IS caliper is post mount. So I can shim the adaptor over no problem..
Maybe I'm over thinking it.. I have never had to shim a caliper / rotor with the post mount adjustability so assumed something on the hub was out of spec..
