Onza Comp 2009 specs
OuchTheBiker
It may be in here mate
http://www.trials-forum.co.uk/topic/124329-new-onza-2009-20-range/
Otherwise i have found
Onza Comp 6061-U6 aluminium alloy frame whichhas integrated chain tensioners, head tube reinforcing gussets and rear diskmount
- Onza alloy oversized 99 riser handlebars
- Onza alloy oversized stem
- Tough Onza cromoly forks which have disk mountand ā€˜v’ brake mount
- Powerful Magura HS33 hydraulic brakes front andrear
- Onza caged pedals
- Drilled double wall Onza rear rim and drilledsingle wall Onza front rim
- Maxxis Creepy Crawler 20 x 2.0" front tireand 19 x 2.5" rear tire
- Onza sealed hubs front and rear
- Onza ISIS crank-set with lightweight aluminiumalloy durable bash-ring to protect the sprocket
- Onza bash-plate fitted as standard
- 18T freewheel
and this
High quality 20" wheel trials bike from Onza, i- High grade 6061-U6 aluminium frame with rear disc mount, integrated chain tensioners and head tube reinforcing gussets.- Tough Onza cromoly forks with disc brake and HS33 mounts.- Powerful Magura HS33 hydraulic brakes front and rear with Tensile 4-bolt clamps.- Double wall Onza rim on the rear and Onza single wall front rim, both drilled to reduce weight.- Onza sealed front and rear hubs.- Maxxis Creepy Crawler tyres, 20 x 2.0" front and 19 x 2.5" rear. Good Tread- Onza ISIS crankset with lightweight aluminium alloy bashring provides a stiffer pedaling response.- Anodised Onza bash/ski-plate fitted as standard.- Onza alloy riser 31.8mm trials handlebar and stem to reduce weight.- Onza caged pedals.- Tensile 60 engagement 18T freewheel fitted to the cranks for great pedalling response
thats all i can see but i can not find if it is a plus frame
Edited by Earl
