Inpulse tensioner problem
seaine
Hey.
I dunno if any of you could help but is there anyway to make a stronger set for the frame I seem to be stripping the tensioner nut on every set I have had!
Anyway you could fit snail cams ?
When your axle bolts are tightened the tensioners shouldn't really be under load so it may be worth seeing if there's something up with your axle bolts and washers. Taking your bolts out and thoroughly cleaning them and the inside of your axle then putting a generous amount of grease on should help. If your axle bolt washers have worn smooth where they contact the frame then replacing them with some new knurled ones would help keep your wheel in place too.
Ok I will give that a go! I replaced them with m5 bolts and nuts but I push the wheel back and tighten them up and tighten the wheel up.
It either holds the chain tight till I put it under power and slips or the hub rubs off the frame and doesn't spin freely .i have viz hubs
