isitafox Posted August 3 Report Share Posted August 3 One for the oldskool in here, am I right in thinking that Echo rim brake lever blades fit on 04 style maggie lever bodies? Can't remember if I'm getting my wires crossed as it's been that long and I always ran 05 levers in the past when I started riding again! Quote Link to comment Share on other sites More sharing options...
Mikee Posted August 3 Report Share Posted August 3 I'm sure that I tried it years ago and it didn't work. Quote Link to comment Share on other sites More sharing options...
isitafox Posted August 3 Author Report Share Posted August 3 2 hours ago, Mikee said: I'm sure that I tried it years ago and it didn't work. Just had a google about RB levers and you had one of those in an 04 and said it was sweet, sure the Echo rim brake levers were very similar. I know the disc brake levers look the same but don't work as they are very slightly different.... Quote Link to comment Share on other sites More sharing options...
Mikee Posted Monday at 04:25 PM Report Share Posted Monday at 04:25 PM RB lever does work with slight modification, as they are slightly too thick to fit. If memory serves, the Echo lever is quite a bit narrower (which could have been overcome), and the TPA/push rod did not line up correctly with the piston; which was the big problem I had. 1 Quote Link to comment Share on other sites More sharing options...
