Magura Hs33
Dan_Mac
....so long as you have the recipte (sp?).
nah you dont need a reicept, just take them to any magura dealer (most good LBS), with all of the bits, brackets, bolts the lot, and they will send them back to magura, they will fix em for you and send em back.
when i sent mine back because or leaky masters and slave cylinders on both brakes (thats the levers and the pot bit on the back) i ended up with brand new levers, and a new slave cylinder on each brake, i also had a brand new sets of pads with them too, this was all free. it took just under 2 weeks for them to come back. i thought what good service that was.
the only thing is, i not sure if theyll do it if it has been bled with anything else other than magura blood, or something similar, for example water, WD40. they may do i not sure.
hope that helped.
