Wheelbuilding Help
Tony Harrison
Does anybody know if the Hope Mono has the same outer dimensions (flange offset and diameter) as the Hope XC/Sport (splined disk attachment)?
I'm trying to calculate the spoke lengths to build the XC onto a BMF/DX32 rim (32H) and I'd rather use Hope's hub measurements (given on their site for the Mono) as they're most likely to be accurate.
Also, does anybody happen to know the inside diameter of the BMF/DX32? I could go home and measure them but I thought I'd ask incase anyone knows offhand.
Thanks.
Slightly different.
Its approx 548 (or 550 if its got eyelets), I've found that 266 drive 268 disc works well with that combo.
Edit: Hang on, which hub are you using Ian? Ta.
