24inch Maxxis Tyre
boon racoon
i need help...where can i get a maxxis high roller 2.5" <<<< note! TEWNTY FOUR INCH
bikedock dont have them (only the 2.7 version)
crc don't have them (only the 2.7 version)
anyone know if 2.7 one is wider than a 2.3" tioga dh24??? (sounds stupid but the tioga is f**king wide)
or any other tyre with good grip and pinch protection?!
similar to a michelin comp24 if poss
cheers like
Edited by the boon
Matt,
Get in contact with bikedock, where I got mine from feburary time, try the guy on southerndownhill forum, Geoff I think it is might be able to sort you out, I got discount on mine.
They wear out well fast though. The 2.5" ones are pretty fat, probably about the same as a 2.3 Tioga, 2.7" ones are pretty massive.
I have always thought the maxxis was quite thinnish my 2.5 isn't any bigger than a 2.35 moto digger!
Not sure where else you try - I know halford can order them in. Oh...actually Tim (Dr Evil on here) mentioned something about them having a 24" swampthing (i hink) in stock at the one he works at, It was a month ago though.
You could try a Intense tires, a bit more $$££$$ though - I ran 2.35 FRO DH - it lasted a long time and grip is awesome I was running it bald in the wet and got it down to 8psi with no puncture (didn't bother going lower) and I was running a halfords tube. The tire has 6ply casing - makes maxxis look thin, I had too run it at about 5psi less to get the same feel as my IRC kujo (which could be another option, should last you ok in the summer and with a DH tube)
hope thats some help
mike
cheers like
Maxxis Swampthing dh 24"*2.5 supertacky dual ply instock bdock £23.99
could be a little heavy though with 2 on
hope this helps
good luck
hope this helps
good luck
ah-ha...looks good. any idea on the weight. not that i really care? (i'm using rear only) the tread looks a bit like a front tyre to me but i'm, sure it will be better than what i have :- wear rate pretty good??
i'll order one today ready for NASS (from CRC cos it's cheaper and i'm confident of their delivery...sorry!) :P
o yeah, thanks a lot!
Edited by the boon
About 1150g, use same delivery service
look again bud
www.chainreactioncycles.com/Models.aspx?ModelID=4616
bdock are cheaper on
42a 2.5" crc on 42a 2.35
:P
hope this helped you more
can't find the weight for the 24" swampthing, but the 26" version is 1180g which is 70g lighter than the 26" highroller, so you are probably looking at 1100g(ish) for the 24".
My highroller is has been going for around 9 weeks, I think i could probably be getting around 3-4 months out of it. but I do ride places on it, because i am a loser who can't drive.
Mike
look again bud
:P
lol too late!
tyre is £25 in CRC but has free delivery
when i went to the checkout on bikedock it was £26 including delivery (£1:99)
i saved a pound! :-
Edited by the boon
I prefer the kujo 24" 2.35" nice tread and profile reasonable pinch resistance just not that easy to get hold of i found.
spealized 24" dh pro is another choice very light but i dont really like it not sure why tread just wasn't for me was running a super think Halo tube (3mm) so punctures where not a problem!
Laurence Fielding Bungalow-bikes.
I think this is where the confusion lies!
Edit: Aaahh i see now... Tomm wants matching tyres :(
Nah. I already have tyres. They do (coincidentally!) match though (Y)
But there are no light front tyres for 24" I think? And I always liked Fire XCs :S
