Magura Bleeds
steve bain
ok, so i've decided my brakes were very badly bled. however my lbs want £15 to do it!!! (that'll be a no then) so has anyone ever made there own kit? as £20 for a few plastic pipes and a syringe seems crazy! it only seems to be the nipples that would be difficult to get hold of or make. any ideas? and no comments about being a cheapskate, i can't help it. steve
ps. go on mousebreaker.com and play the bmx games, there greatly addictive!!
You will need:
A plastic syringe (10ml - 25ml) - can probably buy in a chemists
A small bit of plastic tubing to attach to it
An old Magura cross-over pipe
Some oil (Mineral brake fluid, Halfords, 7 quid a litre, green bottle or cap)
You need to cut the cross-over in half, and attach it to the syringe using the plastic tubing. The cross-over, at one end, should have the threaded barb so you can screw it into the caliper to bleed.
So, for about 10 quid you get your own kit that'll do countless bleeds.
