Pedal Hop Problem
san
I found the best way to learn pedal hops is
roll along slowly then do a small endo
Come down and pull back and start doing little hops on the back wheel (pogos)
Then realise the rear brake and push hard with you good foot forward and hop forward at the same time. then apply the rear brake again before you land.
All this should be done with you good foot forward :)
Not sure if this makes sense to you but this is how i learnt.
(is this what you are trying to learn a sort of standing hop forward on the rear wheel?)
