Tryall Bb Warrentee
chrishayton
has it snapped or the bearings knakerd????
i aint had a problem with mine yet :S and mine has seen some use in the last few days and on my stock since i got the kenny it has had some propa useage!!!! :P
Waynio......................
id be suprised if the axle has snapped????
no a bearing outer race has snapped, bb came loose though so could be my fault
sounds like it was if you rode it loose...........cos the bearing casing is moving there fore putting it under more pressure. i think, if you go to your local bearing supplier you will be able to get hold of replacement bearings as the Try all b/b are strip able. (from what i have been told and heard)
yeh i mite do that then, its a pretty crap bb though, rough as anything(before i broke it) im gona get another fsa 1( that 1 you sold me is still smoooooth) off tarty and then mite fix the other
you wunt know how to strip it would you though wayne
Edited by chrishayton
