Eno Freewheel
Jeza
Hi all,
I had a quick search through tf on the keyword of "eno", but couldnt find any topics on it (ran my eyes down the list) so therefore i admit to not searching through every post as i wanna ride! (Y) ,
So rather than just posting..."use search"
Please would you advise me on why my eno freewheel may be ocassionaly skipping because i would rather it not skip on a drop as it hasnt yet, also ideas and methods of fixing it.
Thanks Jeza
They're quite hard to get open if you haven't done it befor. You take the lockring off and then there's a clip which you need to twang off with a screwdriver, they just forse the shell of it's body.
Good luck. :)
Thanks JT mate, good luck :) sounds as though i havent got a hoping hell
It's when you have to get the shell off the freewheel, then you'll get stuck. Becuase you have to use a hell of alot of jip to get it off.
Putting it back on is easy, you just lay two spanners down so it pushes the shell up, and the body goes between them.
Edited by JT!
