Pads
fezzer
Turn the little red knob on your lever fully off, then turn it so the pads are just starting to move, then undo all the bolts and set your brake up again.
EDIT: make sure you set the pads at an equal distance from the rim.
Edited by ash-kennard
Taken from the mgura cult homepage http://www.execulink.com/~dtierney/wmc/Magura/contents.htm
Q - One of my pads at the rear doesn't retract fully. Why?
A. This is a biggie and it gives lots of people problems! You have your pad adjuster (TPA on HS-33's or allen screw on HS-22's) screwed in too far. This is just a weird characteristic of hydraulic brakes. Screw the pad adjuster all the way out and try again. The pad retracts now? Good - then make the major adjustment of moving the slave cylinder inwards by loosening the Evolution Adaptor brackets. These brackets may be switched side-to-side to get more adjustment.
reported you to Danny to see if you can be validated.
IMO your posts are really good and help full, just time before he makes a decision to validate you :-
