Shimano Mechanical Disc
Shadowfax
firstly they arent exactly ideal with just a 160 rotor size and all......and for the price an avid is a better option
secondly the rotor-is your hub a 6 bolt or shimano spline hub? gotta make sure it comes with the correct rotor fitting
thirdly avid rock and for cable brakes, you shouldnt be thinking of buying anything else (Y)
firstly, i run it on normal deore rotor that is not centerlock, secondly i haven't got the option to buy avid since i have 50% discount in one store that has only shimano discs and i wanted to pay less.
i just asked does the disc brakes good.
AND how much time does it take that the new disc with new pads starts to brake correctly, i think that the pads need some adaptation, while they are completely new they dont brake so good, am i true??
i was merely pointing it out to you dude........some people forget about compatibility issues that arise with shimano products
personally i wouldnt bother with a deore, and just save for a avid, discount or no discount-i doubt you will be as happy with a deore as you would an avid
however, you can upgrade the deores to bigger sizes-i suggest about a 180mm rotor+adaptor, and/or some ebc red pads to increase power
from my experiences with both the hydro and cable versions of the deore brakes, i would say the avid pisses over them and just save (Y) or run a decent v brake which will also piss over it and quite likely be the same price/cheaper
