Echo And Koxx Rims?
Dougster
no facts, but if its "painted" the same way, or even better is the same "paint" thats on a middleburn bash you can defo file it off as thats what i did with mine ;)
same with the front also, or alternatively you could have tarty grind it off like you suggested (Y) you would also have a better braking surface...
my mate has the 06echo rim on the rear and his braking isnt good to put it shortly, he has had to use a lil bit of tar...
hopes thats helped you to come to some sort of conclusion
