Removing And Acs Freewheel
wilky_mod_legend2
take the teethed outer shell off with a hack saw or grinder. put whats left of the freewheel into a vice it needs to be tight. use a mallet or if your not bothered a hammer. and hit the crank arm as if you are unscrewing it off. and it should just screw off once loose hope this helped
how would u take it off, and have a free wheel left at the end????
