Hope Mono Mini Trial.
heli_flyer
I think your right. If your forks have a + 30 mount, you will need a 30 mm larger rotor than that’s normally required for your disc brake. So if you decided to get the Hope mono trials with a 160 mm rotor, you will need to use a 190 mm rotor. I believe that the koxx forxx have a + 30 mount. Try checking on clean bikes or tartybikes to double check first though.
