My Rear Rim
sir trial a lot
Right, basically i oiled my chain today ant i put a little too much on and it has flicked out onto my back wheel. Obviously this has made the rear brake rubbish. any ideas how to clean it please? ive tried brake cleaner and it doesnt seem to have made it any better :(
Any help appreciated.
B)-->
QUOTE(joe b @ Jan 19 2006, 11:24 PM)
Yeah as said above, sand your pads down. But if you can get hold of a blow torch, then take you tyre and the like of and blow torch your rim. Or would that do damage to the rim? :blink:
Cheers,
Joe.
I seem to remember welding two rims together raped the material with Ali C's wheel, and although it wouldn't get as hot with the blow-torch, I don't think it'd be great.
Anyway, the rim: Metholated spirits will clean your rim up so it's all nice and spangly. Alternatively, give it a good grind. Everyone loves a new grind ;)
For the pads, simply rubbing them on a rough brick wall 'til you can see the whole surface has been 'roughed up' is enough, generally. 'specially if you do the new grind idea. Either way, you've basically got to remove the surface layer, and it should turn out all nice again.
Just make sure you learn from your mistakes :P
