Rocking Front End!
petit_pablo
Ive put my new front end together tonight.
New zoo forks, onza rim built on hope pro 2 hub and a hope mono trial disc brake.
When i tested the front brake out, there is a rocking "somethings not tight feel" on the front end.
I checked the headset (fine), the disc on the hub (tight) and the disc calliper (tight).
Could it be the hub rocking slightly when under load?
Any help?
If everything is tight it is almost certainly your brake, the best way to check this is to turn the wheel to 90 degrees with the frame, then try rocking it again. If it still rocks I have no idea if it doesn't then it's almost definitely the brake. (Y)
