Bolt Stuck
ogre
I'm currently playing around with some pedals (caged ones you get witha t-bird) and i can't undo one of the bolts that holds the plates in, any ideas?
Heat. Just a blow torch and heat the bolt up and then try undoing it, watch out though because they conduct heat VERY quickly (as experience told me yesterday).
Watch out not to heat it too long though as they have plastic spacers.
Are they used? Problem might be that they have bent in a certain was meaning the threaded plate is bent, or even the bolt may be bent.
good luck.
